Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 06-02-2005, 01:39 PM
Blk982drTahoe Blk982drTahoe is offline
Question Brake Problems
When I am slowing down to a stop the brake pedal will sometimes start to pump and make a noise. I just press down harder on the pedal and the car still stops, but the whole thing does not seem healthy. I got new pads, and the whole system flushed a few months ago, but this did nothing except now the brake pedal makes a squeeky noise as well when i push down. Anybody have any ideas on this?
Old 06-02-2005, 07:19 PM
TGARST TGARST is offline
The pulsing could be the ABS, If this happens right B4 the truck stops could be a bad front wheel bearing.
Pull the ABS fuse, which will disable the ABS and then see if it stops the funny feeling.
I it does you probally have a bad front wheel bearing.
Tim
03 Yukon
Old 06-03-2005, 09:14 AM
GiGsolydCustoms GiGsolydCustoms is offline
Re: Brake Problems
is the brake warning light on? TGARST has a great point, and advise. could also be air in the brake lines. after flushing the system it is quite possible the mech. didnt tighten the bleeder all the way.
Old 06-03-2005, 12:59 PM
Thanks for the ideas. Im gonna try diconnecting the abs this afternoon and see how it goes. Hope that fixes it. If there is air in the brake lines how would i go about letting it out?
Old 08-18-2005, 12:45 AM
ddesens ddesens is offline
Re: Brake Problems
I have the same problem with my 00 tahoe. I pulled the fuse today and the abs pumping/noise not present when coming to a stop. What does this mean? Did you find the source of your problem?--Dave
Old 08-18-2005, 07:26 PM
Re: Re: Brake Problems
It's a bad front wheel bearing assembly $$$. I just left the fuse out, which disabled the ABS. Then is was back to good ole' pre abs brakes, just pump um!
Tim
Old 08-22-2005, 08:07 PM
Update--I was having the same problem with my brakes. On saturday I jacked the truck up and found out that the left front wheel hub sounded noiser than the right one. I replaced the hub and cleaned the sensor on the right side hub. Put it back together and the ABS problem was gone! Very easy job! This forum helped point me in the right direction!!
