Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-02-2005, 12:44 PM
jeje jeje is offline
Lightbulb Is Scaden A/C compressor good?
Which A/C compressor is best fit for 97 Jimmy. AC Delco? Delhpi? or Scaden?
I read the item description from an ebay seller:
"Had the dreaded and common body leak on your compressor? Not with this one! The original GM HT6 had no internal pins or anything to keep the compressor from 'twisting', which is the main cause of most of the leaks. This unit is pinned at every seam, and will not leak. This pump is manufactured by Sanden, an OEM supplier, as a drop in replacement for the original GM model, preventing the problems with the original."
