Old 06-02-2005, 11:53 AM
spiky1987 spiky1987 is offline
Escort 94 idle ,neutral ... instable rpm (stall)
When i start my escort when the motor is warm oh when its hot outside ...i start it climb to 1900rpm and fall to near the 0 and sometime it stall ... sometime not , when it does not stall , it keep searching a good idle rom for infinite time ... goes up and down between 400 and 1000. Do you know that piece i have to change or clean ??? the gaz , air , oil filters are new the pvc valve is new so what can i do ?? the vacuum lines goes to a little thing ... seem to be a coil with a grey cap and a foam filter ... what is this piece ?????
Old 06-02-2005, 03:09 PM
xviciousx's Avatar
xviciousx xviciousx is offline
Send a message via AIM to xviciousx
Re: Escort 94 idle ,neutral ... instable rpm (stall)
That one piece you mention, I'd have to know where it's located, but from what you're saying I think the problem may lie in your Mass Airflow Sensor or your AIT sensor... when I removed those for kicks I had the same problem.
*I AM NOT DEAD YET*
The REAL King of Space
Angels banished from Heaven have no choice but to become demons...
And you will shed tears of scarlet...
Close this world...txEn eht nepO
This is what happens when you are skilled... you become isolated and arrogant.
Old 06-02-2005, 08:21 PM
Hehehe I found the problem !! it was thwe IAC ... i went to the scrap yard and asked the dude and i put a new one and now it work well
