Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 06-02-2005, 08:24 AM
joe56football joe56football is offline
Question some questions abut 95 jetta gl
I just bought this jetta for my daughter that needed some repairs. I need to know the following.
how do I get the belt on the dual cooling fan do i have to take off the radiator or is there an easier way?
2. the rpms do not work what should i look for in the engine
3 how hard is it to replace the radiator hose upper that goes to 4 different locations
4. the trunk aut open clicks but does not open trunk and I have no key to open it can I go in from the back seat?
any help will be appreciated
Old 06-02-2005, 07:14 PM
lenny0861 lenny0861 is offline
Re: some questions abut 95 jetta gl
pull the 4 bolts out behind the fan it will be hard but I did it in less than a n hour
Old 06-09-2005, 11:31 PM
IowaHawkeye24 IowaHawkeye24 is offline
I have come to be quite the expert with the trunk. Pull back all the carpeting from the inside, or as much as possilbe and stick a screw driver where the locking part is and slide the lock till it pops open. Then you must reassemble the assembly, which is pretty easy to figure out, that is located behind the carpeting on the trunk lid.
