Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-02-2005, 07:27 AM
smeagal smeagal is offline
95 civic wont start
when i turn the key i can just hear the starter spin.
i already got 4 new ones. not one worked.
Old 06-02-2005, 11:54 AM
bill-the-ba$tard bill-the-ba$tard is offline
Send a message via AIM to bill-the-ba$tard
Re: 95 civic wont start
Broken timing belt?
Old 06-02-2005, 02:32 PM
Rampart Crawler's Avatar
Rampart Crawler Rampart Crawler is offline
You should have traded for your fathers corsica when you had the chance.:P
We all know Chevrolet > Honda
Try your father's magic swinging towel.=P
'99 Civic DX Coupe
http://www.cardomain.com/memberpage/835460
Old 06-06-2005, 11:22 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
are you sure you are installing the starter right? sound like it is not even engaging the flywheel at all. Either you are not installing the starter right or your flywheel is shattered.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 06-07-2005, 03:29 PM
It's his flywheel. If he knew how to drive a stick, this wouldn't have happened.
'99 Civic DX Coupe
Old 06-12-2005, 09:09 PM
nmikmik nmikmik is offline
1. At what point (what has happened) you decided you need a starter?
2. Do you hear the starter run by itself or you can hear engine turning with it?
3. If the timing belt broken you’ll “feel” engine turning but a lot easier then usual
4. Try to look trough the starter “window” in the transm. & see if flywheel’s teeth are damaged, then try to turn it a little with the pry bar (taking the spark plug out should/will help.
Old 06-13-2005, 01:46 PM
fordin K fordin K is offline
how do you know its the starter and not ignition switch ? any noise from starter at all ?? need to check if ignition reaching starter solenoid circuit first
