Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 04-15-2002, 10:58 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Unhappy TPS question
Well i let my friend borrowed my tps from my b16. He said his cracked and he wanted to use mine to see if its the problem so he can go out and buy one. Well i asked for it back and he said he threw it out cause it was bad. Even the "shop" said it was bad. So then he said i can use the one off of the stock d16a6. Anyways will it fit? I'm startin to feel suspicous about my friend I don't know if he's tellin me the truth or not?
Old 04-16-2002, 02:20 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
a b16a swap can't be this hard damn that sucks, have you finished your swap yet? i may be undertaking one in a few weeks, WOOOHOO!! alright hope all goes well and beat down n your friend
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 04-16-2002, 07:23 AM
ricodemus ricodemus is offline
spy54 - you will see that little things that you dont really think of end up setting you back. Like for me, a missing bracket for the clutch cable is setting us back a couple days. I'm picking up one today, so hopefully it will fit. Otherwise, I'm screwed. After that gets put in, we can finally test and see if vtec is working, then maybe we can finally drive the car. We cant find the proper pins for the ecu though, so we have to rig it. Only nice thing is that I dont have to relocate the batery because the stinger battery I picked up is so little, the CAI passes right over top of it. It turns out my supposedly new radiator isnt in too good condition, so I ordered a Fluidyne yesterday. I guess it's only money...
I'm a lonely male who'll settle for any phony in a ponytail - MCPB
The b16 is in and running strong
Old 04-16-2002, 09:33 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
TPS
Hey,
Any TPS will fit, as long as the motor was injected. Even the dinky D15 Dual point FI TPS will work. Just make sure it is still good, and that you put it on at the right position. You can test it with a volt meter by hooking it up, and putting the + lead on the middle wire (I think that it is red & black). With the throttle plate completely closed, it should read something like 0.4volts. With it fully open, it should read something like 4volts. If it is in the wrong position, it will throw a code and read funny voltages. If you need one, I have a spare that I ended up with after not knowing how to test it and replacing a good sensor. I think I only paid $25 for it or something. I'll hook you up if you need it.
That is how you know, and forget whatever the "shop" told your friend. I bet he tells you something like, "I bought this one off ebay..." in the near future. That is your cue to beat him over the head with a large, heavy, blunt object for being a trashy liar! (Just kidding, I don't condone violence....) Good luck with your swap. I am undertaking a re-do on my ZC in a couple of weeks, so I feel your pain!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 04-16-2002, 10:08 AM
4GZChatch's Avatar
TPS
Hey,
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 04-16-2002, 11:26 AM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
the TPS off the d15 dual point, will NOT work, for it turns the opposite way and will not fit right because its backwards..ive already tried it...
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 04-16-2002, 11:35 AM
4GZChatch's Avatar
TPS
That's odd... Mine did work, it just threw a code, which I later learned was because the angle was off. I drove it around for 3 days with the Dual point TPS on there... Does the year matter? Mine's an 89. Maybe they changed something?
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 04-16-2002, 07:55 PM
mellowboy's Avatar
Re: TPS
Originally posted by 4GZChatch
Hey,
Yeh my friend said he tested it with the volt meter and he said it got no readings? Man Spy54 trust me ..you MIGHT have all the parts but once everything is bolted on...do not expect the car will start on the first turn of the key. There will always be a small problem which can lead to bigger problem if you are low in funds like me Oh 4GZChatch i would buy that tps from ya but all my last 35 bucks went to EightOhOne for the intermediate shaft that i bought from him. Well my gurl is sendin him the money tomorrow actually. Maybe my friend is tellin the truth? I'm not sure though. I'm not gonna go and point a finger at him and blamin him for that tps. I have no proof that it works or not.
Old 04-16-2002, 09:57 PM
spy54's Avatar
damn man that sucks could you list everythign that has set you back how much did cash you start your swap with and how much are you down to?
AF Teen Crew
Old 04-17-2002, 08:36 AM
I drove mine around the block yesterday, but vtec was not wired yet. Hopefully, after we get the proper pins, the vtec solenoid code and knock sensor will go away. I was only shifting at like 4500, so I was in no way gonna feel much power, although there was a little. engine is kinda loud, probably because of the headers and the shifter is in there completely bare. We beat the hood up a little bit, cai and valve cover were hitting a little. Should look pretty nice when were done. Anyone know how much the b16 weighs vs the d16a6? the car looks lower in the front, but maybe b/c its been jacked up the last few days, who knows...
Old 04-17-2002, 11:12 AM
mellowboy's Avatar
I think the weight difference is like 50-60 lbs? Not sure though. Someone correct me
Old 04-17-2002, 11:16 AM
mellowboy's Avatar
Well i bought me engine with trans and ecu for a good price. 1087.50 So altogether should cost me around like 1600 including the new tps if i can get enough money for it that is. I wish its gonna be a clean swap. Meaning that no broken bolts or no parts breakin while installing the engine. I mean rite now so far so good. Just the money is an issue for me.
Old 04-17-2002, 02:40 PM
spy54's Avatar
see i have to deal with legalities and such and parents so those are my major concerns
AF Teen Crew
Old 04-19-2002, 11:31 AM
mellowboy's Avatar
Unhappy
Does anyone have an extra tps layin around? I mean my "friend" said he'll get me another one but i couldn't get a hold of him?
Old 04-20-2002, 09:01 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
The TPS are not interchangable - you can't even swap them between different series of B16As (I found this out the hard way). Baically it has to do with different angle settings for the different motors - which sucks in itself.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
