Old 06-01-2005, 05:37 PM
redneck45 redneck45 is offline
Autotrac ?
This is my first autotrac. '99 Z71. Why does the front drive shaft not spin freely when the truck is in 2 wheel drive? Or should it? My last two chevy's were '98 Z71 and '04 Duramax 4x4, both were not autotrac transfer cases and the front drive shaft would turn by hand in 2 wheel drive while under the truck and the truck on the ground!
Old 06-01-2005, 08:30 PM
Re: Autotrac ?
Anyone?
Old 06-01-2005, 10:00 PM
silveradoking silveradoking is offline
Re: Autotrac ?
With autotrac, the front driveshaft should spin only when you are driving......when you are in park, it shouldn't move, or only move about 1/4 inch either way......
Old 06-01-2005, 10:03 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Autotrac ?
Yeah, seems like to turn the driveshaft, you'd have to turn the front wheels/front diff.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 06-02-2005, 06:01 AM
Re: Autotrac ?
Ok, just making sure. Cause the regular 4x4 trucks when the truck is in 2x4 the front drive shaft coming out of the diff will spin freely. Not so with this autotrac.
Old 06-03-2005, 07:27 AM
Re: Autotrac ?
Ok, just checked the wifes '04 trailblazer with autotrac, and the front driveshaft will spin freely when in 2x4! I still think there is something wrong with my '99 silvy! I started to trouble shoot it when I discovered a "noise" "humming" when I put it in 4x4. So I checked the ujoints--ok, a little play at the transfer case rear output yoke when you push up and down, hence the "clunk" you get when dropping it in reverse. Everything seems to work ok, only got the "service 4x4" light once but it never came back.
Old 06-03-2005, 03:12 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Autotrac ?
Theres nothing wrong. Mine doesn't spin. IT only turns when in 4 wheel drive or when your in auto 4x4 (which i recommend not using)
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 06-03-2005, 09:09 PM
troy1 troy1 is offline
AF -Advisor
Re: Autotrac ?
I agree dont use autotrac if you pulling or out mudding its very hard and the transfer case clutch pack I would only use 2hi or 4hi.
Old 06-03-2005, 10:40 PM
Re: Autotrac ?
the humming in 4 by 4 is normal.....don't worry man....
Old 06-06-2005, 08:45 AM
01Blackerado 01Blackerado is offline
Send a message via Yahoo to 01Blackerado
Re: Autotrac ?
Uh mine doesnt hummmm
Old 06-06-2005, 12:39 PM
Re: Autotrac ?
Well, just changed all the fluids to Syn. (including the new "blue" transfer case fluid) and truck still makes a "humming" in 4x4, but hey 4x4 still works, and I don't use it that much--if it breaks I'll fix it!
