Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-01-2005, 05:21 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
Fuel system troubleshooting walkthrough
duders -
she wants to turn over, she's dieing to turn over but she just can't. that reasuring fule pump whine is gone. where do i start? relay? fule pump replacement? give me a few checks before i start taking the gas out of my tank.
update -
just now i went out to try and start it for yucks and it fired right up. now i'm confused.
also i am aware how to spell fuel.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 08-18-2005, 09:42 AM
Rock_On_85 Rock_On_85 is offline
Turn your key almost all the way i think its 3 clicks, 4th starts the car......Anyhoo if you dont hear any 2 second winding sound (your fuel pump) then that is what it is, replace the bastard and your car will start.
Old 08-26-2005, 11:49 AM
kmathew kmathew is offline
Re: Fule system troubleshooting walkthrough
You might want to check Fuel pump relay, yes. Check fuse pannel under hood. Look in your manual for location.
If it starts after the engine bay cools down it might be a heat related problem with the relay
Old 09-27-2006, 06:29 PM
paul_meets_mark paul_meets_mark is offline
If your thinking its something with the fuel.....try doing a fuel pressure test, that way you know if the pump is sending fuel.
~Paul_meets_Mark
Old 09-27-2006, 10:36 PM
eggfarmer eggfarmer is offline
yes, I go along with the relay check.
Old 12-10-2006, 01:57 PM
ginBrut ginBrut is offline
looking for the fuel pump relay location on my 1991 tracker??
Old 01-23-2007, 06:23 PM
MarkSS MarkSS is offline
A friend of mine had the same problem in his mustang, the fuel pump was real loud then it just quit one day. We hauled it home and dropped the tank to check all the connections we hot wired the pump to a battery it worked so we put it back in it fired up but soon died. It ended up being the fuel pump.
