Hydraulic Issue with fr. brakes.
Hello everyone. I have a '99 suburban 1500 series, 5.7 vortec, with abs brakes, disk/drum. I'm having problems with pressure not being released from the fr. brakes after the pedal is released. I pressure slowly bleeds off after 10 - 15 minutes. I have replace both fr. flex lines and the master with OEM. Still the same problem. There appears to be no prop valve in the system, just the abs unit. If anyone has had the same problem help would be great. I tired of changin the fr. pads every 2500 miles. Thannks,
Re: Hydraulic Issue with fr. brakes.
Couple questions.Are you sure it is brake fluid pressure keeping the front brakes on or could it be sticky sliders or pitted caliper pistons?Do you have brake pedal freeplay?If no freeplay,the master cylinder pistons are not returning all the way and could be leaving pressure in the line.
chuck's |
Re: Re: Hydraulic Issue with fr. brakes.
If I crack the lines at the master I'm not able to move the pistons anymore. I don't know much about gm abs, is the a one way valve in the abs unit and this condition is normal?? I'm unable to see a prop valve in the system anywhere also, is it part of the abs unit? maybe it doesn't have one at all? Any help would be great I have tried everything that I can think of. Thanks. Mike. I might add pressure is applied to both the fr. brakes its not one side or the other. And rear brakes appear to work fine. My burben has 3 chennel abs and also is 4wd. |
There is a possibility that the ABS unit may be faulty.I'm not very experienced on the workings of the ABS controller.Sorry.
chuck's |
