Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-01-2005, 03:47 PM
GUnitD420's Avatar
GUnitD420 GUnitD420 is offline
Send a message via AIM to GUnitD420
91 eclipse clutch
I was just wondering what kind of clutch I should put on my eclipse. It has the stock one on it right now and I was told to change the clutch while the engine is out. any suggestions? Or should I stay with a stock clutch and if so where could I find one.
91' Mitsu Eclipse GS 5-Speed DOA Selling.
95' Eagle Talon TSI AWD 5-Speed (Overheatin' No More) daily Driver
Old 07-01-2005, 08:41 PM
Chirpn'3rd Chirpn'3rd is offline
Re: 91 eclipse clutch
Is Your Car Stock? I Have A 2500lb Clutch On Mine Right Now, The Pedal Will Be Stiffer, But The Clutch Should Last For Ever. A.c.t. Has A 2100lb Clutch That Should Do It For You.
1990 Tsi AWD ( DEAD )
2001 GOLF GTI ( LOVE IT! )
1986 300ZX ( TOO OLD )
Old 07-01-2005, 09:40 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Gunit... It all depends on what you want to use the car for. Street/strip type of driving, daily driver and so on or just race. I'm guessing daily driver is the case so you can go with several different company's. I just started using Southbend clutches and they are very nice. I have a 3200# pressure plate with a pedal pressure of less than stock so its very easy to push down. Thats why I like DXD (Southbend) clutches, plus they are fairly cheap.
You could go with a ACT 2100 but the pedal would get a little stiffer as stated already. There is also Exedy and Centerforce who make decent clutches.
Just some information that I came across and found to be very interesting and everyone should remember... Every company that make clutch kits for street use get their clutch disks from Exedy. Some companies just grind off the name on it so you cant tell. So dont let a company try to fool you and over charge you for something you could get cheaper from somewhere else.
Make sure you get the flywheel resurfaced to .610 +/- .002 and you'll be good to go. Replace the throw out bearing too, usually they come in the clutch kit if you go that route.
Now for Chirp'n3rd...
#1. Please turn off the caps lock. Makes it hard to read!
#2. Private message me what kind of VR4 motor do you have in your Talon. I'm interested in seeing pictures of it if its what I think it is.
Old 07-06-2005, 03:40 AM
i1nk83 i1nk83 is offline
Send a message via AIM to i1nk83
prob just a galant vr4 motor, nothing special at all
1990 mitsu eclipse gsx
16g
550's
burned eprom chip
2g mas
3" turbo back custom exhaust
port&polished head, turbo, exhaust mani
mml headgasket
b.s. elimination
centerforce df2
unorthodox crank pulley
autometer boost , a/f
hallman es mbc
homemade fmic and piping
relocated battery lower in engine compartment
purty candy red valve cover
stripped interior
couple of random guages
man this is a big list of nothing special......gotta work on that
50trim in the works
Old 07-06-2005, 08:24 AM
kjewer1 kjewer1 is offline
AF - Advisor
I think its also worth mentioning that according to his sig the original post has a NT car. Even a 2100 seems like overkill But as usual, I have no experience with the NTs...
Capitalizing the first letter of every word does indeed make it tough to read. And its a lot of extra work for nothing
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
