Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-01-2005, 01:09 PM
triplel triplel is offline
Vent Selector, A/C and Recirc Not working
1995 Suburban K1500 w/5.7L w/rear air
Vent selector, A/C and Recirculate buttons. Not working..
Checked both fuse boxes. Changed A/C Relay under hood. Is there another fuse or relay under dash that could be hidden. Manual does not indicated another?
Blower works and heater. When fuse (if fuse) went, the Vent selector was on Floor.
First noticed after I hooked up neighbors trailer wires to my adaptor plug.
Link? I do not know.
Any suggestions?
Old 06-01-2005, 04:50 PM
crownedroyal crownedroyal is offline
I had that same problem with my "99 burben, it ended up being the heater control panel. One of the power lines on the paper part of the circuit board had gone bad. I was able to solder a small piece of wire over the burnt spot. I hope this helps.
Old 06-01-2005, 06:21 PM
Re: Vent Selector, A/C and Recirc Not working
I will take a look at that.Where is this circuit board?
Old 06-01-2005, 11:16 PM
Re: Re: Vent Selector, A/C and Recirc Not working
Sorry I should have been more clear about that. You will find it behind the heater control panel. The burn portion was on the "paper?" that connects to one of the plugs. The bunt line was visible and I able to solder a line from one of the solder point to where the connector connects to the control panel.
Old 06-02-2005, 09:08 AM
Makes since. I searched last evening for another fuse. Nothing. Now to figure out how to get my dash apart. I did notice a square gray relay strapped behind the ash tray. My burban has a lot of options, alarm, gps, mobile phone. Needless to say, a lot of wires stuffed under the steering column. I am going to attempt it on my own though.
Thank you for your help.
Old 06-08-2005, 10:02 PM
Finally got the time to reach the Circuit Board.
The circuit board that sometimes cause trouble is the one with wires plugged into it from ac, recirc, and vent selector dials?
Mine seems to be hard plastic, instead of cardboard.
My Uncle said it is a common problem for the circuit board to go bad, like mine did. Sure is hot w/o air.
