Old 06-01-2005, 11:49 AM
4G63t Power 4G63t Power is offline
Horrible Luck...
Ok... I have a problem. My brother broke his shifter fork the other day. So... He decides to take my car to slowboy to get a new one. He was cruising about 70-75 and all of the sudden he said my tires locked up, unlocked, and locked again. He managed to get the car pulled over. Him and a friend that went looked over the entire car. Nothing out of the ordinary, nothing hanging down, no spattered oil, nothing... So they start the car and its running fine, no problems. He went to pull out and the car is making a metallic grinding sound once the clutch is fully engaged. The car has no power and it feels like the clutch is slipping or burnt up or something. The car moves a little but again it feels like a slipping clutch and is making a grinding noise. Were dropping the tranny today to check it out. Anyone know what it can be. I thought it might one of three things. Clutch, flywheel, or a friend suggested it may be something in the transfer case like the output shaft could have snapped. Im not sure at this point and when I get home ill tear it apart. The problems not in the engine or the driveshaft... the noise is coming from the tranny. Any suggestions on what it is? Now neither of us have a car and to make it worse I just ordered a brand new Evo III turbo and ported Evo manifold and itll be in Monday. Figures. Anyhow. PLEASE HELP!
AWD sold
New car*
90' Eclipse Gs-T
Shaved head with rebuilt motor
Slowboy racing limited slip
compression 165 across the board (:
Fully ported Big 16g with 34mm flapper
Precision racing Fmic
Slowboy Boost controler set at 15lbs
Custom 3 inch turboback
Fully ported o2 housing
Ported 2g manifold
Slowboy racing UICP
3 inch hard intake pipe
SAFC
Autometer carbon fiber gauges
Putting down a solid 300whp
1/4=13.7 at 109
That mph is good for high 12's with traction (:
Old 06-01-2005, 05:57 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: Horrible Luck...
I'm no tranny expert but the grinding noise may be due to a worn out throw out bearing. Mine grinds a little with the clutch fully engaged only. Although i have no slipping clucth symptoms.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 06-01-2005, 06:46 PM
kjewer1 kjewer1 is offline
AF - Advisor
There is a recall for the tcase, they sieze and lock all 4 tires. Happened to mine, and many others. Pull the tcase drain plug before dropping the tranny, if ntohing comes out, you've found the problem.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-02-2005, 09:21 AM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
I think i found it... The rear axle is able to be pulled out of the rear differential. Yeah... haha. But would this cause the grinding noise up front?
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 06-02-2005, 09:25 AM
Sorry... accidentally posted on my bros name. Thats why its tsipsi20 instead of 4G63t Power.
MOD LIST:
