Old 06-01-2005, 11:30 AM
lorddarkice's Avatar
lorddarkice lorddarkice is offline
More help with my eclipse lol.
so right now i have found out that the MAF is bad (getting another soon) so i am going to say that is the reason the car runs rich, and has a somewhat ruff idle. the gas could be getting bad as well, which would be helping that along (ruff idle).
the real problem ATM: the turbo is not boosting. i know the turbo is good (at least good enough to boost) because when i had the manifold off and was spraying the motor off with the air hose i shot it down the turbo (were you could see the turbine wheel) for a second and it spun, and pushed air out of the air outlet (the hose was taken off as well). so i am wandering if the wastegate is stuck open? would that make it unable to boost at all? and is there anyway to check for that. the guage in car is not really reading much of anything. its pretty much stuck on -7 .
1990 Honda Civic Hatch - 3 motors, SOLD
1998 Honda civic EX - nothing done, SOLD
1990 BMW 325IS SOLD
1992 Plymoth Laser RS SOLD
1992 Mazda Pro-to-gay Given away
1995 Saturn SL2 SOLD
2002 Toyota Camry LE V6 bone stock.
Old 06-01-2005, 12:16 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
it cant be the wastegate cause even if the wastegate was always all the way open you would still have some boost, whenever you give it gas do you hear it spool up?almost sounds to me like you have a hose or pipe off somewhere, did you check all your connections and make sure everything is hooked up?
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 06-01-2005, 12:29 PM
Re: More help with my eclipse lol.
yeah, everything is tight. after going over everything i realize the wastegate rod was off the pin? lol, not sure how that happened. at any rate, going to check it now, but had to come get my keys.
edit: still showing no boost. however, i took the hose off of the BOV and put my hand by it after reving it up some and there was deffently air flowing out of it rather hard. so the turbo is pulling boost? didn't see the wastegate move at all. i am about to go and get a cheep aftermarket boost guage and hook it up somewere fast so i know if just the guage is broken?
1990 BMW 325IS SOLD
Old 06-01-2005, 02:03 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
well if you drive the car you should know if you're boosting or not, you'll be able to feel (and hear) when you hit boost.
95 Talon TSI AWD
97 Eclipse GST
Old 06-01-2005, 02:39 PM
how does the stock unit measure boost? its not a 'real' boost guage right? is it linked to the MAF?
and because the maf is not working right the car is running VERY rich. i dont have a guage on it, but you can smell the leftover gas. so yes i drove it, but not very hard at all. i just wanted to let it get hot and get some working load on it.
1990 BMW 325IS SOLD
Old 06-02-2005, 06:51 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
What the hell are you trying to boost for without a functioning MAF!
With the MAF not functioning the ECU will run the car in limp mode. This is a predetermined A/F ratio that is designed to get you to a garage/home upon critical sensor malfunction. Obviously to be safe, the car runs pig rich. I know the ECU can control boost via the BCS, but to what extent I don't know.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 06-02-2005, 11:36 AM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
I think that your stock boost gauge calculates what you car should be boosting at.
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
