Old 06-01-2005, 10:34 AM
goshman goshman is offline
Dash indicators on a 91
I have the semi-circle type indicators on my dash. The oil pressure rides in the normal range at idle but stays buried at the max under acceleration and while cruising. Is this a problem or is it normal?
Old 06-01-2005, 05:54 PM
98SilvyKid's Avatar
98SilvyKid 98SilvyKid is offline
Send a message via AIM to 98SilvyKid
Re: Dash indicators on a 91
This might be a problem if the pressure is too little or too excessive for the given engine speed. After idle, you should have a little under 10 psi for every thousand RPM (So I've heard). Checking your filters and pump might be a good place to start.
1998 Chevy K1500 Standard Cab, Flareside Cargo Box,
All Options, 5.0L V8, 4L60E -K&N Filter, Custom Exhaust, American Racing Rims, Manik Brushguard, CF Light Shades, Glasscapes picture, More to Come!
Old 06-01-2005, 09:44 PM
mbumgua's Avatar
mbumgua mbumgua is offline
If the needle buries at higher speeds it usually indicates a bad sending unit.
