Old 06-01-2005, 06:50 AM
xtremehp482 xtremehp482 is offline
Send a message via AIM to xtremehp482 Send a message via Yahoo to xtremehp482
98 Taurus High Beam Dash Light
Ok, I was checking all the bulbs on my instrument cluster, and I came acrss a bulb for the high beam light. Well, this bulb has never lit when my high beams were on, so I checked to make sure the bulb was still good. It tested good, and it worked in other bulb ports. Then I tested the wire giving the voltage, and it tested like 4-5 volts. Any suggestions? Not having it is fine, but since my car has the bulb, why not use it?!?
Old 06-06-2005, 08:00 AM
mcconnc mcconnc is offline
I have the same problem w/ my '98 Taurus. High beam light indicator on dash doesn't work. My has flickered on and off intermittently as well. My advise, get used to it and don't worry about trying to fix it. I've noticed that the high beams aren't that bright anyway and most oncoming cars don't even flash me when I forget to dim them!!
Old 06-07-2005, 01:53 PM
KimMG KimMG is offline
AF - Advisor
Re: 98 Taurus High Beam Dash Light
Check the ground.
