Old 06-01-2005, 02:26 AM
dsinnie dsinnie is offline
geo metro steering knuckle removle..
91 geo metro, how do i remove the steering knuckle from the ti rod?
it seems like it should just slip off after you remove the calper key and nut, but it doesn't budge banged on it for an hour.. any ideas?
Thanks.
Old 06-01-2005, 01:33 PM
geozukigti geozukigti is offline
It's a real bit@#. When that nut tightens down, the tie rod's tapered edge really gets stuck in the steering knuckle. Spray some PB blaster in there, maybe heat it up a bit. Just keep banging on it, maybe a bigger hammer too. Don't damage the threads if you're planning on re-using the tie rod end tho.
Old 06-01-2005, 11:24 PM
pind pind is offline
Re: geo metro steering knuckle removle..
Ok, quick and easy
Take wheel/ tire off, remove caliper and pads if so desired.
Remove the cotter pin from the tie rod end nut, and loosen the nut using a 17mm wrench or socket. Don't remove the nut from the tie rod end completely yet.
Take a bottle jack, or scissor jack, or whatever you have, and set it under the nut. Lower the car onto the jack until a good part of its weight is supported by the jack, then give the steering knuckle a couple sharp smacks with a hammer, right on the end where the tie rod end goes through. this will pop the tie rod end loose. then remove the jack, finish spinning the nut off, and remove the tie rod from the knuckle.
Be careful not to hit the tie rod end though, you will pretty much destroy it if you do.
Happy Whacking
Old 06-03-2005, 04:39 PM
thank you
Old 10-31-2005, 03:55 PM
pw4090 pw4090 is offline
I have 1996 Geo Metro and I resently replaced both the left and right front wheel bearings. I had to remove both steering knuckles and I used a ball joint/tie rod fork to seperate the tie rod from the knuckle. it did take some time but it did pop loose with the fork.
Thanks.
