Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-01-2005, 02:24 AM
baileconmi baileconmi is offline
Unhappy loud squeaking noise until engine warms up
I just bought my mustang and it makes a loud squeaking noise until the engine warms up, whether driving or idling. I don't know anything about cars at all... but from reading other questions, could it be a loose belt?
Old 06-01-2005, 02:31 AM
stang805's Avatar
stang805 stang805 is offline
Send a message via Yahoo to stang805
Re: loud squeaking noise until engine warms up
more than likely, get a bar of soap somthing like irish spring, and rub it on the belts, (engine NOT running), if it stops squealing or isnt as bad yes its a belt (easiest way to figure it out short of tightening everything)
Old 06-02-2005, 10:29 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Re: loud squeaking noise until engine warms up
Well, there's only one belt and usually the serpentine belt will not squeak.
Noises such as you describe are extremely hard to resolve over the Internet. Try and get a more detailed explanation of where the noise is coming from. Open the hood, listen, touch things, you can even use a few feet of rubber hose as a stethoscope to help pin point the source.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 06-02-2005, 07:27 PM
stang805's Avatar
i've seen serpentine belts squeal several times, especially if they are old, not saying this is the problem, hence the very easy way to tell, rub some soap on it, and he didnt even say what year it is so it may not be a serpentine, the first thing i would check, yes, would be the belt(s)
Old 06-03-2005, 12:21 AM
benchtest benchtest is offline
1) The next time it squeaks, shut it off immediately and pull the belt off. Start it briefly and see if the squeak is gone.
2) If it's gone, while the belt is off, check all the accessories for loose or damaged bearings. The idler in particular. They shouldn't wobble front to back. If you find nothing, try a belt.
3) If the squeak didn't go away with the belt off, you've got engine problems.
I'm assuming you've checked for belt tension by now.
Remember: Don't confuse noise with horsepower! and Junk is junk, even when it's on sale!
"I would never doubt your expertise....it's obvious you wrote the book on stupidity!" DD
Old 06-04-2005, 01:31 AM
stang805's Avatar
ok, i know you've heard a lot of things here, tell me, whats easier, soap, or taking the belt clear off? I am a ford MLR and ASE certified mechanic, let me know what happens with the soap thing and i'll try to help you out k.
