Old 06-01-2005, 01:10 AM
bonez86 bonez86 is offline
Oil
I have an 04 3.3 grand caravan. I was just changing the oil, switching to synthetic.. I was wondering how much oil it should take...
Thanks
Old 06-01-2005, 05:50 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Oil
If I remember correctly the 3.3 takes approximately 5 quarts with filter!
Old 06-02-2005, 03:03 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
i usually put 4 then check it with the dip stick to see the level and add untill it gets to full
Old 06-02-2005, 06:20 PM
vipergg vipergg is offline
Re: Oil
Thanks
5 quarts with a filter change .
Old 06-03-2005, 01:52 AM
Marine2's Avatar
Marine2 Marine2 is offline
Re: Oil
Thanks
I have a 2005 DGC with a 3.8. I see Dodge is now using a 5W20 oil in it, which I hear is almost like a synthetic. The wife's 2004 Honda Civic is also using it.
Old 06-03-2005, 02:58 PM
cbwilsha cbwilsha is offline
Re: Re: Oil
My 2005 T&C with 3.3 engine uses 10W-30 in any temperatures above Zero F (-18C). Below that, it uses 5W-30. 5W-20 is not even mentioned in the Owners Manual.
C.B.
Old 06-03-2005, 04:16 PM
Marine2's Avatar
Re: Re: Re: Oil
C.B.
That is funny. On my oil filler cap it says 5W20. In the owner's manual, under fluids and capacities, it says for 2.4 engines, 5W30 For 3.3 and 3.8 engines, 5W20. Both Chrysler products, both the same year,but gives different grades for the same engine.
Old 06-05-2005, 03:22 PM
Stretch58 Stretch58 is offline
Re: Oil
Thanks
My 2000 3.3L Grand C. takes 4.5 qts. with filter per the owners manual.
I would look at your manual.
Here is a link to a Chrysler site to purchase a book if you need one.
https://techauthority.gltghosting.co...atalogId=10051
Old 06-09-2005, 08:54 AM
OSUCowboy27 OSUCowboy27 is offline
Re: Oil
Thanks
Only put in 4.5 Quarts! My 2003 3.3 G.C. takes 4.5 with filter but the manual says 5. Being overfilled by 1/2 quart can cause poor fuel mileage. Might be a good idea to just add 4 and see where you are at.
