Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 05-31-2005, 10:18 PM
CaseyVR6 CaseyVR6 is offline
clunk
2000 Jetta VR6 MT 188,000 miles
I've got this noise that comes from the front end of the car. It is best described as a *clunk*, usually one, never more than two (*clunk clunk*). It shows up durring hard acceleration, firm brakes, and sometimes durring slow (sharp) turns like in a parking lot.
I noticed it showed up almost directly after replacing the right CV joint/axle. For the record, it broke before I replaced it. Any ideas? Any easy ways to isolate the problem further, or completly?
Old 06-09-2005, 09:59 PM
Gee_Dubya Gee_Dubya is offline
check your control arm bushings
My 99.5 Jetta is doing the same. Check your control arm busings. Check the front bushings--they are probably torn like mine.
Old 06-10-2005, 10:12 PM
Re: check your control arm bushings
That's a good heads up... I was actually thinking it may be the sway bar bushings, or even the transmission or engine mounts. Drag is I've only got an apartment garage and a small floor jack to work with so it's difficult to get around and under and look properly.
I so desperately need a friend who has a driveway and a fully outfitted garage...
Old 06-12-2005, 05:04 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
WHat did you torq the axle bolts to on the trans side? They should be 25ft lbs each and the axle nut should be i think 220 then back off 2 turns then 240nM
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 01-16-2006, 09:11 AM
Re: clunk
To Close this post:
The clunking was the struts up front. I replaced everything except the stock spring (ran out of money or that would have been done too). The car has no more clunking and squeaking/grinding. The control arm and sway bar bushings look like they will be the next cause for noise. Also to be noted, although not the cause for the noise, the garage I used to have my cv/axle replaced put the wrong bolts in at the transfer case... so I had to go to the dealership and have them swap out the bolts and torque them down right.
