Very Dark Oil
Ok, so about 6K miles ago I ran a gunk engine flush through per the directions on this site. I changed the oil and put in Mobil 1 5W-30. After about 6K miles I noticed some oil leaking and I have never had an oil leak previous to this. I lost about a quart before I changed the oil, figured I would just change it instead of adding a quart. When I changed the oil I noticed it was much darker then usual, basically it was black and almost had a watery consistancy. Never had this issue before the flush or before switching to synthetic. I have never changed the oil and had it that dark before. I think I am leaking from the remote oil cooler lines. Any ideas guys on why the oil is all of a sudden so dark and why I am all of a sudden leaking from the remote oil cooler lines? Thanks!
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
the color is probably from old residue still left in engine and pan from the flush if this is opnly the first change since the flush. also synthetic oil is much thinner than conventional oil, and leaks can occure with a thinner oil, have heard it alot when switching, especially on older high milage.
Re: Very Dark Oil
Its not that synthetic is bad. ppl give me this all the time at work "i switched to synthetic and you said my oil will keep the motor cleaner." well actually the detergents in the synthetic will clean your engine as you drive. All the sludge build up thats blocking parts of your motor from being lubricated will be broken up and brought down into your oil pan. Eventually after all that crap is gone it will be clean. I used synthetic on my last truck when i bought it at 60k til 100k then i sold it. it didnt start showing up clean until aound 80k.
As far as leaks. I dont believe synthetic oil causes leaks or any of that bs. The leaks are already there. synthetic will make them more noticable because of the way it flows so readily and cleans so well. It goes back to the detergents. Remember all that dark oil that came out. Thats all the crap that turned into gel and got stuck in the motor in areas. That gel was stuck around parts that have gaskets b/t them. when you put in synthetic it cleaned it out. exposing the cracked gaskets to the oil, thus causing it to leak oil. Hope that clears i up a lil bit for ya. sucks that your leaking oil. Find where your leak is. if its something easy. replace the gasket and torque it back down to its torque value. IE Oil pan Gasket. well good luck dude. |
Re: Very Dark Oil
You sure you leaked a quart, you could have burnt a quart over 6000 miles which is not abnormal.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: Re: Very Dark Oil
Re: Re: Re: Very Dark Oil
The drop to the add mark could have been from the oil being so dirty that it started to burn. I know my engine will not burn a drop and then all of a sudden it will consume a lot more just before the oil change. This is normal. Just be patient, the leak might be temporary and the synthetic will reswell the seal with the new oil.
Didn't notice any leaks today, have not checked the oil but did not see any spotting on the ground. I think I will change the oil more frequently for a while until it starts looking cleaner longer. Didn't know synthetic would really clean that well, it is truly amazing. I am getting the oil at such a cheap price it is no big deal to change it more often. If I expierence more leaking I may switch back to regular oil for a while to see what happens.
Re: Very Dark Oil
My truck does the same thing blazer. 2500 miles no oil burnt off. b/t 2500 and 3000. it will burn a half quart. If your going to take your truck 6000 i would not switch back to conventional.
Re: Very Dark Oil
Sometimes the gasket on the oil filter will stick and stay on the housing, this will cause the new filter to leak.
When I switch my Blazer over to Mobil1 the rear main leaked for a while then quit. Now, I go 6,000 miles and don't lose a drop. |
Re: Very Dark Oil
I was told by my mechanic after he engineered the oil pan so i wouldnt have to replace that that my rear main was goin because its still dripping. I was wondering if it was because i switched from 10w40 to 5w30 i am on the second full change since then had about 3 in between to try and fix the pan leak myself im gonna go back and see if that fixes it. hard to sell a rig with an oil leak but amazingly i can get 2000 if i trade it in which is pretty cool
1991 Chevy S-10 Blazer 5.7 V8 RIP 1999 Chevy Blazer 2dr 4.3 |
Well........ The leak, now possibly leaks, have seemed to slow down. I am now seeing oil dripping from the drain plug and by the remote oil lines. But not much, even since the weather has gotten warmer and run the ac it has not seemed to drip anymore, maybe even less. Who knows, we'll see, just don't have any money to do any major replacing of anything!
Re: Very Dark Oil
The seals will reswell.
The oil drain plug leak can be fixed with a new washer. The cooler line leak can be fixed by replacing the lines.
Re: Very Dark Oil
Welcome back LT did you have a good trip? I had my leak fixed just leaking at seals
