Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-31-2005, 04:41 PM
axumempire axumempire is offline
96 Camry - Window Regulator - Dashboard light
Hi folks. I've a 96 Camry and need to replace the driver side power regulator & motor. I already checked the master switch and it works just fine. Can you guys give me instructions how to replace it? also the dashboard light that lits up the AC switch does not work. I suppose there's a lamp that I need to replace?? If so, how can I do that? thanks!!
Old 06-02-2005, 11:58 AM
quincyguy quincyguy is offline
R you sure? Checked for a bad wire, connection?
Some good stuff in here about power windows, going back over the last
month, or so.
You really wanna do a continuity check with a cheapo shirt-pocket
MM from RS or whomever
"The only easy day was yesterday"
---- US Navy Seals
Old 06-05-2005, 01:48 AM
Yea I checked the wiring and it appears to be fine and the master switch is working as well. Any ideas how to replace the lamp that lits the dashboard behind the AC switch? thanks.
Old 06-08-2005, 01:27 PM
Re: 96 Camry - Window Regulator - Dashboard light
I believe that switch has the small led built into it. No seperate bulb
behind the a/c sw.
Old 06-08-2005, 03:47 PM
InstallTech's Avatar
InstallTech InstallTech is offline
I had that same light go out in my 93 Camry. It's a little, tiny bulb that costs about 8 dollars at the dealership. You'll have to pull the dash around the radio and remove the trim from around the instrument cluster to get at the AC/Heater switch assembly. From there, just take out the screws that hold in the AC/Heater switches, and it should be pretty easy from that point to get at the bulb. Can't remember if the dash from the 93 is the same on the 96, but I'm pretty sure they are. Either way, the removal will be fairly similar.
I reject your reality, and substitute it with my own.
