Old 05-31-2005, 03:28 PM
jlshondacrx90 jlshondacrx90 is offline
02 simulator for b16, do you need one?
hello, i was wondering if you need to buy an o2 simulator for the b16, becuase my check engine light is coming on and it idles and accelerates bad
Old 05-31-2005, 03:37 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: 02 simulator for b16, do you need one?
do you have both o2 sensors hooked up, or at least have both o2 sensor wires hooked up to one sensor?
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-31-2005, 04:45 PM
i have them both hooked up, i ran that 2nd o2 sensor to the ecu
Old 06-01-2005, 12:34 PM
EF You's Avatar
EF Life Giver
did you use shielded wire? because if not, its gonna pick up interference
Old 06-04-2005, 03:15 AM
no i didn't use a shielded wire
