Old 05-31-2005, 01:45 PM
dlivingston dlivingston is offline
Question Freeze plug replaced, not starting
98' Blazer LS, The freeze plug had a hole rusted and while driving the water drained out. The vehicle shut down, towed it home and replaced the freeze plug. Moved the starter out of the way to do this, and the engine would not turn over. Replaced the starter and still the same problem, checked fuses (OK), checked coil/distributor/spark plugs/fuel/etc. (OK). Everything has power and seems to work, but the engine will not kick in to start. Could it be a computer shut down when the water ran out - got to hot?
Old 05-31-2005, 03:25 PM
herkyhawki herkyhawki is offline
Re: Freeze plug replaced, not starting
If starter is good, and is engaging the flywheel, and battery is fully charged, but starter cannot turn the engine over..The engine may have seized from overheating.
First double check the battery or use a booster/charger while trying to start.
Old 05-31-2005, 03:42 PM
Thanks,
Will try that when I get home.
Old 05-31-2005, 10:05 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Originally Posted by dlivingston
Thanks,
Your engine will not shut down do to overheating, it will seize.
There is no heat protection circuit for our engines.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-01-2005, 07:02 AM
Unhappy
The battery is fine. The engine has not seized. I'll have to take it in and have it hooked to the computer, maybe that can tell me what is wrong. Please be something simple and cheap!
Old 06-01-2005, 07:33 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Well, to check if it's seized, remove the serpentin belt, then using a breakbar, rotate the crank if you can't move it at all it's seized. (might wanna remove a sparkplug while you do that as well. )
Old 06-02-2005, 07:36 AM
rlith's Avatar
Any word on this one?
Old 06-17-2005, 08:34 PM
BlazerLT's Avatar
AF -Advisor
guarantee the engine is shot.
If it won't turn over, no computer will cause that problem.
