Old 05-31-2005, 12:52 PM
Hanster24 Hanster24 is offline
Send a message via AIM to Hanster24
car problems
i have a 96 GST spyder. i was on the freeway yesterday, i down shifted, the press the clutch again to up shift, and ass soon as the rpm statred to go down, the inside lights dimmmed out, now im in 5th, and the car want to stop running, its feels like is about to stall. Anyways i pull over and turn the car off, the turn it on, and its doing the same thing, the lights are dimming out, if i press the gas they'll come back to normall, so i held the rpm's around 4000, and the it ran fine, and i drove it for about 20 miles so far, it works but my Check engine lights has been on since i started to pull over!!!!!!!!! it did this once b4, but that time was when i was in reverse and i stalled the car.
Old 05-31-2005, 01:07 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: car problems
Take the car to autozone and have them pull the code for the CEL.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-31-2005, 11:21 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Well your lights are doing that because they are running off your alternator and when its givin less pwr then the lights and etc. have less pwr 2 run off of so they dim...jst so u know, I wouldnt think the cel would coorilate what so ever sounds like a clutch issue, do you have to give it lots of throttle to get it moving all the time? or just on the freeway?
Old 06-01-2005, 02:28 AM
Re: car problems
k,i went to autozone and they said it was a 301 - a misfire in cylinder 1..
the car does not need a lot of throttle to get it moving
