Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 05-31-2005, 12:43 PM
Jeff Stoveken Jeff Stoveken is offline
Question '97 Power Train Control module
I apparently have a bad PCM. No voltage pulses to the fuel injectors, just steady voltage slightly below battery voltage. It is the same for all injectors. Question....is the PCM replacement a straight old out / new in trade or is there set-up procedures required?
Old 05-31-2005, 06:32 PM
sharo23 sharo23 is offline
Send a message via AIM to sharo23 Send a message via Yahoo to sharo23
pcm is easy to replace but need dealer scanner to progarm or the parts
department have a box that they can program pcm for you if you purchase part from them.
pc pcm is coverd from factory 8years 80000 miles.
can you get any codes from the sys try that before replace parts.
