Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 05-31-2005, 11:29 AM
arif1616 arif1616 is offline
problem with my 96 altima brake lights
I have a 1996 Nissan Altima and yesterday I noticed that my brake lights were on. I checked my headlights, the emergency brake, the brake fluid. Everything was fine. The car was driving fine and my battery was fine. The brake lights were just on, whether the engine was on or off, whether I was pressing the brakes or not. Does anyone know why it may be doing this? and if so, how can i fix? i disconnected the battery so it wouldn't die but i had the drive it today, and it drove fine, and when i got back i disconnected to battery again so it wouldn't die, but when i connected it again to take it to the mechanic, the car wouldn't start at all...help!?!
Old 06-01-2005, 08:36 AM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: problem with my 96 altima brake lights
The brake light switch is under the dash near the top of the brake pedal. It is adjustable. Look for worn bushings or a broken pedal return spring that would cause the adjustment to change.
Old 06-01-2005, 05:57 PM
Re: Re: problem with my 96 altima brake lights
Thank you so much....What exactly does the switch look like?
Old 09-05-2005, 02:21 PM
acj003 acj003 is offline
Send a message via AIM to acj003
Unhappy Re: Re: Re: problem with my 96 altima brake lights
I have an identical problem with my 1994 Nissan brake lights staying on; however, I have determined, by disconnecting the wires to the brake light switch, that it is not this unit that's causing my brake lights to stay on. I am at a loss to find out the cause of the problem and wonder if you have solved your brake light problem.
Old 10-06-2005, 02:01 PM
mike171562 mike171562 is offline
Im having the same problem with my gf's car, does anyone have a solution, the problem persists even when the brake light switch is removed?????
please help
