Old 05-31-2005, 09:28 AM
pirho451 pirho451 is offline
vibration from front end while braking
Hey guys,
My '94 LeSabre is driving me insane! When I bought the car, there was some minor pulsating in the front brakes when I'd hit the brakes lightly(it's gotten MUCH worse in the ~1500 miles I've driven it). If I push down hard on the pedal it goes away. Also, turning the steering wheel just slightly either way seems to help the problem. I've taken off the wheels and I know that the pads/rotors have some uneven wear to them(looks like the previous owner NEVER had the rotors machined), but the rotors don't look warped (I took those off for closer inspection). I'm planning on having the rotors resurfaced and install new pads next time I get paid, but is there anything else I should look for? The car stops perfectly fine, but the shaking or whatever it is HAS to go.
Old 05-31-2005, 04:29 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: vibration from front end while braking
I would try a brake job before anything else. Plus it is probably cheaper just to get new rotors because out here they dont resurface rotors.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 05-31-2005, 05:45 PM
dean,can dean,can is offline
its your rotors my car did the same thing also so i changed the rotors and the pads.problem fixed.
Old 06-01-2005, 07:15 AM
Yeah, I know that the auto parts store near my house will resurface rotors, but it might be cheaper to buy new ones (that plus I dunno if they are even good enough to BE resurfaced).
I'll keep you guys posted as to what happens.
Old 06-03-2005, 09:18 PM
urbancaveman urbancaveman is offline
if the brake job doesnt fix it check the wheel bearings and/or the 1/2 shaft (cv shaft). if the rotor is warped you wont be able to see it with the naked eye you'll need a dti (dial test indicator). you can get a cheap one at use-enco.com for under $20. also, i've bought cheap rotors and they sucked...vibrated, heated up fast, and wore out real fast. same for cheap pads. i'm as cheap as they come, so i wouldnt say this unless it was worth it... blow a couple extra bucks on good pads and rotors and don't let the rotors get to thin before replacing them. they'll pay for themselves in quality of braking and duration.
