Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 05-31-2005, 09:24 AM
jber jber is offline
89 tbird
hello
i have a 89 tbird , the compressor clutch wont kick in, ive cked all the fuses an they are good , i can use a jumper wire to the clutch an it works fine , the charge in the system is good , the low pressure switch is good , can someone tell me were the compressor relay is located, thats the only thing i cant find to ck
thanks
Old 05-31-2005, 10:46 AM
stang805's Avatar
stang805 stang805 is offline
Send a message via Yahoo to stang805
Re: 89 tbird
did you jump the low pressure switch connector, if you do that and it kicks on its not the relay, also, how do you know the switch is good? the relay is the least likely thing to go out on an A/C system
Old 05-31-2005, 12:16 PM
yes i jumped the low pressure switch conn with a wire, an cked the switch with a vom to make sure it had condinuity thru it everything cks ok but the compressor just wont kick in so the relay is the only thing i think of that may be bad
Old 05-31-2005, 02:37 PM
stang805's Avatar
Re: 89 tbird
so if it didnt turn on when you jumped the connector, the relay is in or under the black fuse box under the hood i think
