Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '88 - '92
Old 05-30-2005, 11:50 PM
jtiderencel jtiderencel is offline
Send a message via Yahoo to jtiderencel
timing belt 92 passat, 9A engine
need to know. changing timing belt on 92 Passat GL, got the timing marks on camshaft, the the crankshaft set. the distributor # 1 mark
off a little, can get with adjusting. how to tell if valve are damaged? can pull valve cover, but to lazy.
Old 09-04-2005, 11:09 PM
passatGLwgn passatGLwgn is offline
Re: timing belt 92 passat, 9A engine
Are you on the exhaust stroke or intake stroke??? Is there lots of smoke? Pollutions and terrible (load of hot wheels in a cement truck) Noises are always a dead giveaway to signs of valve bendage.Does it run...etc...etc.
