Old 05-30-2005, 11:12 PM
98gsmits 98gsmits is offline
Turbo Boost To High
Okay I have a 98 eclipse with a 2.0 liter N/A engine. I have a garett t-25 installed from a 95? eclipse. I just recently fixed an exhust leak on the manifold. My boost was 11psi at first but now that it's sealed up it will go up to 18psi and the wastegate no longer opens? What is wrong with the wastegae and why is the boost so high? How can I get it back down to 11 or so?
Old 05-30-2005, 11:48 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Turbo Boost To High
first of all i don't know why you're boosting at 11 on a n/a engine, ESPECIALLY a 420a. you can boost safely around 7-8 on a 2g n/a engine. i'm surprised you haven't blown it yet but i wouldn't drive it (or even run the motor) until you get that fixed. do you have a mbc?
95 Talon TSI AWD
97 Eclipse GST
Old 05-31-2005, 12:04 AM
I'm running 11 because I have low compression pitsons in..weisco 8.8:1. I didn't just put the turbo on without internal upgrade. MBC? I am very new to this I usually am a Pushrod V-8 type of guy but I assume your reffering to a boost controller which I do not have.
Old 05-31-2005, 12:10 AM
mbc = manual boost controller
i think your boost problem is caused from the wastegate not opening. there was another guy on here recently that had a similiar problem (i think, don't quote me on that). do some searching and you might find your answer.
95 Talon TSI AWD
97 Eclipse GST
Old 05-31-2005, 12:15 AM
thanks, how easy is it to get a manual boost controller and is it easy to install?
Old 05-31-2005, 12:30 AM
Whathits14 Whathits14 is offline
easiest install you will ever do....about as complicated as putting a cd into a cd player.....ok not THAT easy but you could teach a chimp how to do it.
you can get a joe p mbc for $40 will work fine.
www.boostcontroller.com
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 05-31-2005, 12:47 AM
As for the wastegate not opening though? any thoughts, i'm having a hard time searching the forums to find anything?
Old 05-31-2005, 08:21 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
The wastegate or actuator is broken if you are getting higher than 10psi. A boost controller can only increase boost over the actuator's spring, not reduce it. If the wastegate did not open at all, you would be getting higher than 18psi, probably around 23 depending on elevation.
