Old 05-30-2005, 09:58 PM
Caprice Classic LS Caprice Classic LS is offline
Need Help - Sound issue
Hi everyone,
Two weeks ago I had a new panasoinc deck (CQ-C1301U) installed in my caprice classic. It works pretty good with the bose amp. Having the ability to play mp3 is great as well. But here is my problem. When I leave from work at the end of the day I start the car and turn on the deck, it plays for about 2 minutes and then the sounds shuts off. Now in the morning when I drive to work this does not happen. I park underground in a garage that stays nice and cool. When I leave work the cab of the car is quite hot at first. This seems to be the only difference I can figure. When the sounds shuts off the deck still functions normally - just no sound. If I shut the deck off and right back on it will play for a minute or so shut down again. However, if I leave the deck off for like 4-5 minutes as I am driving and then turn it on it will be fine and it works and sounds great. The only info related to this in the manual is if DEW is a problem.
Any suggestions to what is happening would be greatly appeciated.
Thanks!
Old 05-31-2005, 02:21 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Need Help - Sound issue
does this happen at any volume or just when it's turned up high
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-31-2005, 07:38 AM
Re: Re: Need Help - Sound issue
This happens at any volume. Thanks
Old 05-31-2005, 10:47 AM
sr20de4evr's Avatar
Even with it all the way down? So the headunit is still on it's just not doing anything?
I'm just trying to figure out if it's over heating or not, since you said the cabin is hot when you leave work and it's not when you leave your home, it seems like the first logical answer. And since it's summer I assume you have your AC on, and since the vents are normally right by the headunit that would explain why if you leave it off for a few minutes and then turn it on it works fine, because the AC vents cool it down so that it's back in its operable range again.
That's the only thing I can think of
'01 Black Sentra SE
'05 Silver WRX STi
