Old 05-30-2005, 10:27 PM
enve enve is offline
autometer 5" tach w/ shift light prob
I wired the tach to the correct spot that vfaq told me to, yet for some reason it reads 1k rpms when im at 2k, 3k @ 6k, 500@ 1k, so on, its only giving me half a reading, how do i fix this?
Old 05-30-2005, 10:37 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: autometer 5" tach w/ shift light prob
Whats wrong with the original tach?
oh and you have to directly connect it to the ecu. I can't remember the wire, so I won't post it so you can't fuck something up by trying it.
....It has been a LONG time...I want to move to FL or Japan.....
Old 05-30-2005, 10:41 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
are there any adjustments on the back of the tach for different types of igniton systems?
drewh my guess is he wants a bigger one obviously his original one works if he knows exactly how far off the new one is
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-30-2005, 11:23 PM
lukedogg8706 lukedogg8706 is offline
Re: Re: autometer 5
Some people don't like reading posts all the way.
98 TSI AWD
Old 05-31-2005, 12:00 AM
drewh4386's Avatar
No my thing is whats wrong with the first one. Are you blind or something? A bigger tach.
Old 05-31-2005, 12:03 AM
drewh4386's Avatar
Re: Re: Re: autometer 5
Some people tell half stories and lie about what they have and what they did. I was covering first base. wasted money.
I would also like to add that if you need a shift light, you need a auto tranny. If you can't manually shift in the right area, you need auto. Get you shit set to shift at max rpms.
Old 06-01-2005, 12:40 AM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
mine did that too at first, the FAQs I read never seemed to wrk right 4 me, rather than trying to cnnct near the ecu or w/e try the middle wire comming off of the coil pack, its near or on the intake manifold, its a white wire, if that doesnt work then your tach is set wrong, play around with the 2,4,6 and see which one sets it right
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 06-03-2005, 07:19 PM
werd, i have it wired to the 24 pin connecter on the white wire (rpm read out) i tapped into that wire. There are adjustments on the gauge for 4, 6 and 8 cylinder engines, i have it set to 4 cylinders. still only half the reading. Trying to figure it out once i get time, ill try to wire it to the white wire in the bay near the intake manifold like endless posted.
