Old 05-30-2005, 09:14 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
oil temp gauge install?
i recently bought an autometer oil temp gauge and was wondering if anyone has installed one. The instructions say that there has to be a hole drilled and an adaptor nut welded to the pan. now i was wondering if there was any other way of installing the sender? could i tap in before the oil pressure sender? i don't want to have to drop the pan and i don't have access to a welder, so if theres any other way to do it that would be great. thanks for the help.
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 06-03-2005, 08:06 PM
Re: oil temp gauge install?
any ideas please help...........
Old 06-05-2005, 06:08 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
You should be able to tee off the oil pressure sending unit....
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 06-06-2005, 10:48 AM
alright great thats what i'm gonna try thanks for the help .
