Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-30-2005, 08:28 PM
stevefx19 stevefx19 is offline
Send a message via Yahoo to stevefx19
AC problem
My 94 Bonneville SSE AC works but the air that comes out is barely cool at all. So I went to auto zone and bought a can of R134a stuff that looks like a can of fix a flat. The guy at auto zone showed me what valve to put it in, so we both tried however nothing would go into the valve its like the valve is stuck or something is there a way I can fix it myself????
Old 06-13-2005, 06:02 PM
sellncars's Avatar
sellncars sellncars is offline
Send a message via AIM to sellncars Send a message via Yahoo to sellncars
Re: AC problem
It might not take any if your clutch on your compressor isnt working. Do you know if the compressor clutch is turning on? If not you maye have to jump the switch on the accumulater/ receiver drier.
Good luck,
Sellncars
1999 Chevy Malibu, 3100V6 VIN J with 73,000.
1997 GMC K1500 EXT cab, 350 Vortec with 164,000
Old 08-25-2005, 07:27 AM
Dewey68 Dewey68 is offline
Re: Re: AC problem
I am having the same problem with my 92 Bonny! How do i jump it to start my compressor? My compressor is not engaging after i retro fitted to R134.The compressor was working before when it was running with R12. Please help. Thanks
Old 08-25-2005, 08:42 PM
CDJr CDJr is offline
Re: AC problem
To jump it out, you unplug the plug going to the switch and use a piece of wire between the slots. But you must be careful doing this, as its there to protect the compressor from running when its low on refrigerant. So if you force it to run except when charging it up, you run the risk of burning up the compressor. ONLY DO THIS WHEN CHARGING THE SYSTEM!
