Resonator Removal
I have searched high and wide for a pipe that will allow me to remove the resonator from my GTP. I am in the process of putting on a set of TOG headers and I will be using a Randon Technology cat made for the headers. I want more sound and would like to remove the resonator and put in a straight pipe back. I plan to cut the resonator off and connect the pipe just behind where resonator is located.(I can't afford a full cat back system at the present time, spent my extra money on the headers and cat.) I am looking for a pipe that will bolt directly to the cat and pipe without having to weld it. Do any of you know where I can purchase such a pipe? I have looked everywhere and can't find one. Thanks in advance!GTP Dad PS. It needs to be about three feet long. |
Re: Resonator Removal
How do you plan on handling the rear 02 sensor in that configuration? Simulator? ![]() Thrasher CAI, DHP v1.0 ECU, Granatelli CAI Tuneable MAF, 3.4 SC pulley, Hi-Flow CAT, u-bend delete, 180 TS, TB spacer, MSD 8.5mm wires, AC Delco 41-932 spark plugs, Goodyear Gatorback Serp. & SC Belt ET: 14.3 @ 96 mph
The cat I want to use has a built in bung for the sensor right after the cat. Just didn't want to use the resonator. I will probably take your suggestion and have a pipe made for the application. Thanks!
Re: Re: Resonator Removal
