Old 05-30-2005, 07:04 PM
Hairytoad Hairytoad is offline
Send a message via MSN to Hairytoad Send a message via Yahoo to Hairytoad
Running rich on fuel?
What are the ways to fix running rich on fuel on the 94's.. i know a lot of that bs is computer done, so i expect it would cost a lot but im just kind of curious... Also is it that big of a deal to worry about? thanks
Old 05-30-2005, 08:58 PM
CreepingDeath94 CreepingDeath94 is offline
unless it is running terribly rich I wouldnt think it would be that big of a deal...possibly the temp sensor may have some issues. If the computer thinks it is colder outside than it is it would run rich...
Old 05-30-2005, 09:29 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Re: Running rich on fuel?
could be a bad O2 sensor.
Could be a dirty Mass Air Flow Sensor(use the keyboard cleaner spay that you get at like best buy and just spray it towards the wires in the maf..just don't break them loose).
I would bet on an O2 sensor..but just unhook the negative battery cable for 2 minutes, let it idle for a minute or 2 then go out and drive. If that doesn't work, check the O2s if you shake them and they rattle you need new ones.
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 05-31-2005, 09:45 AM
Okay thanks i'll try that, are the o2 sensors exspensive or hard to fix?
Old 06-01-2005, 04:02 PM
tri-power's Avatar
tri-power tri-power is offline
Try runnin codes first to try to pinpoint the problem. A rich engine can foul plugs prematurely and cause excessive damage to the catalytic converter.
