Old 05-30-2005, 06:46 PM
JCL82 JCL82 is offline
Question about piston slap...Does it hurt the engine ?
Soo every morning I wake up and start the 02'silverado i hear it slapping,it only slaps for like 5 seconds .I already took it to the dealer twice,they said it's normal.Then I did some reading,alot of people are having the same problem.My question is jsut for peace of mind.Will there be any damage to the engine if it keeps doing that ?
Old 05-30-2005, 06:57 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Question about piston slap...Does it hurt the engine ?
Piston slap occurs in vehicles from most every manufacturer, not just GM. GM's piston slap may be a lttle more widespread, but I might debate that. Everything I have read about piston slap indicates there is no reliability/longevity issue to speak of with it. The biggest complaint is that it can be annoying. Here is one from a guy with a Pathfinder, you can read about it here:
http://townhall-talk.edmunds.com/[email protected]/817
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 05-31-2005, 01:52 AM
Moose is loose Moose is loose is offline
It is MUCH more common with GM vehicles than with any other brand. GM just won't fix it. Case in pont, my '04 Ford Escape had it; not bad, but had it. Ford bought back my Escape last month because of it towards an '05 escape. GM won't do that unless threatened with an active lawsuit. Is it determental to the life of your truck/car? Well, the sound alone should be enough proof for anyone with an ounce of common sense to say "YES". It is more than an "annoyance". I did not pay 35K for a new truck to wake the neighbors in the morning with a clatter reminicent of a 6.2L diesel. It is wrong and if GM won't owe up to it then thay are WAY behind the other automakers in securing future buyers.
Old 05-31-2005, 03:07 PM
kenwood guy's Avatar
kenwood guy kenwood guy is offline
Send a message via Yahoo to kenwood guy
so this is in fact bad for the engine???
Simon R
2001 Silverado W/T 4.3
124,000
Old 05-31-2005, 03:16 PM
It's debateable, but most everything I have seen on engines with piston slap (not just GM) would lead one to believe that the engines with piston slap last just about as long as the ones that don't have it.
Old 05-31-2005, 03:19 PM
now would this be more common in a colder climate???
Simon R
124,000
Old 05-31-2005, 04:14 PM
nineball481's Avatar
nineball481 nineball481 is offline
My guess... is the slap comes from the lack of oil in the engine at start up. So that said, It really shouldn't be more noticable in colder climate than warm other than it might last a little longer in cold weather due to thicker oil. However this is just my educated guess. I am one of the lucky one's. My truck does not do this, at least not more an a second or two. I also live in the upper midwest (cold winters).
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 05-31-2005, 04:24 PM
Use Royal Purple or Amsoil or another good synthetic and say goodbye to dry starts.
Old 05-31-2005, 05:14 PM
actually,i'm using amsoil.But a heavier oil,10w-40...I'm going switch back to 5w-30.
Old 05-31-2005, 10:53 PM
internic internic is offline
piston slap is not due to a lack of oil as much as when the engine is cold the pistons are not as tightly in the bore as when the engine is warm. it goes away when combustion heats up the piston sufficiently to expand it into the bore. I think GM used pistons with short skirts in the vortecs, so when the piston is cold it can move around slightly
Old 05-31-2005, 11:45 PM
if thats the case then its not that big of a problem......Right???
Simon R
124,000
Old 06-01-2005, 04:22 AM
i havent heard of anything horrible happening cause of it. my 99 does it whenever its like 50 or below outside, and ive got 130,000 miles on it so far and still goin strong.
Old 06-01-2005, 07:22 AM
See?
Old 06-01-2005, 12:25 PM
broughy84's Avatar
broughy84 broughy84 is offline
my 96 does it and i have 98k on it and so does my venture and i have 100k on it. It is really just annoying, some say that it can score the cylinder wall, but I have seen absolutley no proof. Even if an engine fails that has piston slap, how often can that failure be attributed to the slap? probably never. Most of the time anyway.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 06-01-2005, 12:35 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
i have heard of alot of trucks doing this and have not heard of any problems. i heard using different oils will help but nothing will actually cure the problem. i can't see how it would cause any problems since so many vehicles do this and the manufacturers dont do anything about it.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
