Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '83 - '90
Old 05-30-2005, 06:26 PM
Jenn77 Jenn77 is offline
Unhappy 89 Jetta idling at 3000rpm
HELP! I've got an 89 Jetta Wolfsburg Edition, 1.8L, DOHC, 16v. It seems to drive fine, but when I'm sitting still, it's idling at 3000rpm. I messed with the idle adjustment screw and the rpm's dropped, but only to about 2200. Any ideas?
Old 07-05-2005, 09:57 AM
buck88 buck88 is offline
Banned
Send a message via MSN to buck88
Re: 89 Jetta idling at 3000rpm
yeah what you need to do is, read this carefully its vital ok
1.throw a brick through the DRIVERS side window
2.open your hood and pour water in the brake fluid
3.light your car on fire(most important) and then drive it into the FRONT of YOUR house.
all those steps should fix your problem.....how about just take it to your local volkswagon dealership....cus u know that usually helps
Old 07-05-2005, 06:35 PM
zagrot zagrot is offline
Send a message via Yahoo to zagrot
buck, you are quite a sarcastic ass for someone who asks as many questions as you do. it sounds like a vacuume leak is causing your engine to idle high.
Old 10-09-2006, 12:16 AM
BNS_maZda BNS_maZda is offline
also make sure you check all ground wires coming off the intake, i had the same thing and i found a rusted ground wire on the intake
Old 10-15-2006, 08:05 PM
jammyjim jammyjim is offline
it could be your idler control valve. They have a tendency to get stuck open. Does it happen when you first start it, when it gets warmed up, or all the time? Also, you should never mess with your idle adjust screw. It is factory set.
