Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 04-15-2002, 03:20 PM
hinggu hinggu is offline
fog lights
yo guys, this may sound dumb but how the hell do you change the fog lights?? the instructions tell me f all. Please help!!!
Friends Don't Let Friends Drive Stock-K&S Racing Development
www.kandsracing.com
AEM CAI
Custom Apex-i N1 cat back
Old 04-16-2002, 09:17 AM
Sentra Styling Sentra Styling is offline
Send a message via AIM to Sentra Styling
Try this....It should help you out
http://www.b15sentra.net/modules.php...at&id_cat=2#19
2002 Nissan Xterra SE Black
1993 Sentra SE-R Black
1994 Sentra SE-R Red
All SR20DE powered...
Old 04-16-2002, 04:48 PM
thanks a bunch styling, i will give it another shot
www.kandsracing.com
AEM CAI
Old 04-16-2002, 05:36 PM
It's really easy though....you loosen the one screw underneath then you look up at the back of the assembly and see the 2 white tabs with a round metal piece in the middle just push the metal pieces and slide the fog light assembly straight out the front of the car......Remember the whole assembly comes out.....
Old 04-17-2002, 03:22 PM
thanks again.. i still havent had a chance to try it again since it is like snowing and raining here in Calgary
www.kandsracing.com
AEM CAI
Old 04-17-2002, 03:53 PM
Are you just changing bulbs?
Old 04-19-2002, 09:33 AM
SpecVTo SpecVTo is offline
Recently changed my fog lights, wasn't so bad.
Here's what I did:
1. Jack up the front of the car for clearance
2. Get under the front so you're looking up at the fog assembly
3. 10mm socket to remove the black bolt at the bottom of assembly
4. Use small flat head screwdriver to seperate wire connector and disconnect. Don't unclip the wire connector from the car frame just yet, it makes it harder to seperate.
5. Now, use same small flat head to un-clip the lower half of the wire harness from frame. Carefull, you don't want to break the clip as it is plastic and is part of the connector.
NOTE: This step is necessary cause the wires are not long enough and the fog assemlby won't come all the way out, unless you unclip from the frame.
6. Now that the fog assembly is disconnected, give it a good firm push forward towards the front of the car. The entire unit should pop out.
7. Once the fog unit is out....the rest is a piece of cake!!!
8. Put the darn thing back the same way you took it out!!!
Old 04-20-2002, 02:32 PM
thanks guys..yeah i'm just changing the bulbs. i got the HID style bulbs for my headlights and my foggies don't match so i figured i should change them too
www.kandsracing.com
AEM CAI
