Go Back   Automotive Forums Car Chat > Buick > Century
Old 05-30-2005, 05:07 PM
aquadood aquadood is offline
A/C Fuse locations
96 Century Custom 3.1. Looking for any and all fuses that would affect the A/C clutch. Clutch coil ohms out fine, but no voltage to comp.
Old 06-07-2005, 09:22 PM
BuDog BuDog is offline
I have a similar problem on my '99. The only fuses I've found are under the hood in the fuse/relay center, and there should be a diagram when you open the cover. For A/C clutch there are 3 items:
1) Relay
2) diode
3) 10 amp minifuse
I've replaced my relay and fuse (can't find a new diode at the auto parts store) and the A/C compressor still will not run.
What causes an A/C compressor not to run if you've ruled out electrical???? There is good freon pressure, the dashboard switch works fine, serpentine belt is correct, and the compressor worked well a few weeks ago. I hate to think it, but I guess the clutch or compressor suddenly went bad. Any other thoughts??
