Old 05-30-2005, 01:16 PM
scavengerspc scavengerspc is offline
Power to fuel pump
Hi all.
My old 87 s10 Blazer (2.8 auto) must have broken a clip on the small wiring harness that goes to the oil filter housing. The wires got snaggd on the front driveshaft and ripped every wire from the 2 plugs on the housing. Now there is no power to the fuel pump.
I was told that I can temporarily bypass if I can get power to the wire that leads directly to the fuel tank.
Anyone know how to do this so I can get it to my house?
This happened a while ago but a work accident took me out for a while.
Thanks to all and drive safe today.
Dave
Old 05-31-2005, 10:24 PM
Ok let me try this.
Does anyone know the proper location for those wires on the sending units in the housing?
The plastic plugs are gone.
Dave
Old 05-31-2005, 10:38 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: Power to fuel pump
you could check out autozone.com and their repair manual. Its a chiltons manual online with alot of wiring diagrams
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 06-01-2005, 07:32 AM
blazee's Avatar
blazee blazee is offline
Problem?
Are you talking about the wires to the oil pressure switch? If so, you should be able to just twist the wires together and get power back to the pump. You need to check the fuses, too, and make sure one didn't blow while the wire were being destroyed.
Old 06-05-2005, 03:25 PM
Thanks guys.
I had been hoping to avoid just twisting the wires together but it appears that may be my best option after all. Auto Zone didnt have exactly whaty I needed.
I will just get the hot wire and find which one goes to the tank as best I can.
Thanks again.
Dave
Old 06-06-2005, 02:20 AM
JA no Y's Avatar
JA no Y JA no Y is offline
I had the wires on my 88 get caught in my front driveshaft also. Chewed them up pretty good too. I just went to a salvage yard for a couple of replacement plugs. That way I could just match up the colored wires.
