Old 05-30-2005, 12:44 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
How easy is it to replace the lower ball joints?
How easy is it to replace the lower ball joins under the front hubs? Is there a procedure. Is it possible to do it yourself?
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 05-30-2005, 02:25 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: How easy is it to replace the lower ball joints?
its actually pretty easy. just take the brake caliper off, take the CV nut off, and then take off the whole front knuckle. then beat the balljoint out with a big hammer. and then carefully beat the new one in with a hammer. tap all the way around the whole thing when you do it so you dont damage it.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-30-2005, 09:45 PM
Mrock Mrock is offline
Send a message via AIM to Mrock
Get a ball joint remover tool..you'll thank yourself. I was stubborn and declared I didn't need one..yea, after about 5 minutes, I gave in and borrowed one from a buddy.
ZC powered '91 CRX...JE 10:1 pistons, Crower rods, Bullfrog cams, Throttle body bored by Gude, Port and polished head, AEM adjustable cam gears, 340cc injectors, MSD SCI ignition, Cold air intake, clutchmaster stage 2 clutch, aluminum flywheel/heavy duty pressure plate, zex nitrous kit.
Waiting to arrive (and install, to get this baby running!)
Walbro fuel pump, PWR radiator, PM7 ECU
Look out, I can run 17's allllll day.
Old 05-30-2005, 09:57 PM
EF You's Avatar
EF Life Giver
ive never had a bit of trouble with banging it out. if you have the whole knuckle off the car its cake.
