Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 05-30-2005, 11:47 AM
del sol kid del sol kid is offline
Send a message via AIM to del sol kid
hooking a tach up into my del sol
hey guys need a little help here. i have a 1994 del sol.. i have a auto gage tach i wanna hook up to it. i had a freind tell me he knew what he was doing but i dont think he does. he said u have to hook the red wire to the positive side of the batterie, the negative on the negative side, the white to the fuse box/running lights, and the green wire to the back of the gage cluster.. but i dont think it worked. can neone tell me how to get the job done right. it has a shift lite
Ryan
Old 05-30-2005, 12:01 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: hooking a tach up into my del sol
yup that's right. The red doesn't have to be directly on the battery (neither does the negative), just as long as it's at a power source. Check out autometer's website for the instructions in pdf form.
Old 05-30-2005, 12:11 PM
Old 05-30-2005, 12:14 PM
ok now do u know what wire he has to spice into or what not behind the gage? he hooked it all up like that but it didnt work, so i mean maybe there is a specific wire you need to hit in order for it to read the rpms on the tach
Old 05-30-2005, 12:30 PM
thankyou
Old 06-02-2005, 05:22 PM
CivicSpoon's Avatar
There is no Spoon
It will be a blue wire (not the one for the SRS either). No other wire behind the cluster will work, it has to be that specific wire. You should also be able to hook it up to the ECU at pin A21.
Old 06-16-2005, 11:35 PM
E Honda's Avatar
E Honda E Honda is offline
Send a message via Yahoo to E Honda
Re: Re: hooking a tach up into my del sol
On my 93 civic over by the master cyl is a blue wire with a plug on the end.....It works for my tach.
