Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 05-30-2005, 10:04 AM
Sandrakrr Sandrakrr is offline
Send a message via AIM to Sandrakrr Send a message via Yahoo to Sandrakrr
1991 T-bird with starting problem
We have a 1991 T-bird 3.8 liter 6 cylinder. We don't drive it often. Went out one morning and it wouldn't start. It turns over and over, but won't start. We have replaced the coil, the ignition control module, battery, EEC relay. We checked the Inertia swich in the trunk. We tried to jump it by shorting acoss the post on the solenoid. We have tried to reset the computer by pulling the EEC and trying to crank it and reinstalling the EEC, but still nothing. We have checked for spark by pulling the Primary wire at the distributor and also removed the boot. No spark. Anyone have a suggestion on what to do next? Thanks
Old 07-14-2005, 12:03 PM
chrisk95bird chrisk95bird is offline
I had similar problem with my 95 bird. I replaced the stator in the distributor and it was as good as new.
Old 09-07-2005, 01:17 PM
RedDrag0n RedDrag0n is offline
Send a message via AIM to RedDrag0n Send a message via MSN to RedDrag0n
Have you tried resetting the emergency fuel pump switch in the trunk? I had the same problem in my 91 t-bird, and it took me awhile to find the problem. Located in my trunk on the left hand side near the gas filler is a black box with a red button switch that you push that allows the fuel to run. It might be the same for yours, but that's what worked for me.
Old 09-07-2005, 05:01 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: 1991 T-bird with starting problem
That little red button is the fuel cutoff switch. He has no spark. Maybe a squirrel chewed through your wiring harness.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 09-08-2005, 10:39 AM
97Bird's Avatar
97Bird 97Bird is offline
or mice.....
Old 09-08-2005, 01:05 PM
I would grab a wiring diagram and starting checking for voltages before and after each component in the ignition circuit. While suggesting a squirrel ate your wiring (or the mice, even rabbits) may sound like we were joking, we were not. It has happened. It's even possible you have no power coming from the ignition switch itself.
