Old 05-30-2005, 09:19 AM
mrfirebird mrfirebird is offline
overhead console question
i know yellow is power , should it be a constant power or a switched power through the key?
also, how do you calabrate the direction? doesn't make any difference to push both buttons at the same time.
01 F150 Supercrew 4X4
01 F150 4x4 regular cab
67 Honda Superhawk CB77
07 Honda Civic
Old 05-30-2005, 07:32 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
Re: overhead console question
Yellow is serial data signal
Orange is +12V always on battery
Dk green +12V switched (ignition)
Old 05-31-2005, 06:57 AM
i guess what i should have ask, is at the readout it self.yellow is power, i have it working,but did you guys have a constant power on the yellow or is it through the ingition switch.
07 Honda Civic
Old 05-31-2005, 07:12 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
At the display itself, yellow should be serial data. If you run that to power you're gonna fry the display.
Old 05-31-2005, 03:34 PM
ovp0's Avatar
ovp0 ovp0 is offline
Question overhead console
Can an overhead console be easily installed in an 05 Blazer that didn't have one installed at the factory. Are the wires already there?
Old 05-31-2005, 03:53 PM
rlith's Avatar
Can easily be installed, but the harness is not already there.
Old 05-31-2005, 08:15 PM
chcknugget's Avatar
Are you saying the diagram is wrong? What did you do for the orange wire?
Old 06-01-2005, 06:55 AM
i don't have orng on mine.
i have yellow=power ,
grk grn=vss,
grn.blk=temp ,
blk/wht=ground.
gray, brown =dash and dim lights / not connected
so is the yellow to a constant power or a switch power
i have it to a switch power and thought that maybe why i can't get the compass to read correctly.
not a big deal the temp works but the direction is off.
07 Honda Civic
Old 06-01-2005, 07:23 AM
rlith's Avatar
Re: Re: overhead console question
grk grn=vss,
grn.blk=temp ,
blk/wht=ground.
Ok, pin 14 to constant, pin 7 to switched. Now by OFF that it's not coming on period or is it not showing the direction properly? If it's not showing the direction properly you need to calibrate it.
Old 06-01-2005, 08:03 AM
it's not showing the correct direction.
tried pushing both buttons ,doesn't help.
07 Honda Civic
Old 06-01-2005, 08:43 AM
rlith's Avatar
Find a very large empty parking lot. With the temp/direction displayed, press and hold both buttons until the unit displays CAL. When it does drive in tight circles 3-5 times until the unit calibrates and returns to normal.
Old 06-01-2005, 10:39 AM
thanks i'll give it a try
you guys have been a great help and patience in doing this project thanks again !!!!!!!
07 Honda Civic
Old 06-01-2005, 12:40 PM
chcknugget's Avatar
Does the compass stay on? Soes it only show one direction? What do your other functions say?
Old 06-01-2005, 02:10 PM
temp is on and close to correct
compass is on and changes direction , but not correct direction. example ,west may read sw or north reads nw
07 Honda Civic
Old 06-01-2005, 06:47 PM
you guys are the cats a** thanks again
07 Honda Civic
