Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 05-30-2005, 08:48 AM
italianomarcus5 italianomarcus5 is offline
Send a message via AIM to italianomarcus5
Question projector headlight question
has anyone ever had the headlight start to fog up on the inside and if so do u kno any way to fix it?
Old 05-30-2005, 11:16 AM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Re: projector headlight question
Aftermarket lights usually do.
Just make sure its dry then reseal it with a clear silicon. You can find this at home depot..I used fish tank sealant..Worked just fine no fog.
03.IS300.MT.LSD. 'Supra in Training'
Old 05-30-2005, 03:15 PM
cool thanks man
Old 05-31-2005, 03:05 AM
Silverbolt Silverbolt is offline
Exterior Guy
Send a message via AIM to Silverbolt
Take off the headlight
Take out all the bulbs
Take a blowdryer and shoot it into the headlight socket and let the hot air flow out the other holes/sockets to evaporate all the air/moisture and flow out
By clear silocone sealant and just fill in the gaps of the headlights. Theres no need to open and re-seal. Just fill in the crevase (sp) between the back/housing and the clear front lens.
"Take your time, do it right, and NEVER settle for less."
"The only stupid question, is the question not asked."
Old 06-18-2005, 11:37 AM
moedizy moedizy is offline
i have a probelm wit my projector lights just happened yesterday, when i turn on my low beams my high beam bulbs come on but very dimm.....my halos work fine but the problem is that i am only getting light from the drivers side low beam because the passanger side low beam and high beam are both dimmed., HAS N E ONE ever heard of this happening. Its crazy and IM stuck don't know what to do??? NEED HELP?
Old 06-19-2005, 11:45 AM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
One, stop posting the same question in multiple threads. Two, stop posting in month old threads. Three, use the search function. Four, read the damn guidelines before you start posting.
