How do you seperate the transmission from the engine? Clutch fork holding the release bearing.
I would have thought that the release bearing comes out with the trans.
Re: 1994 passport manual transmission removal
Ha Ha its attached to the pressure plate which is bolted to the fly wheel. "pull type clutch MUA transmission"
Anyone have any info??
According to my Chilton, you have to remove the flywhel inspection cover and use a long pry bar and pry it loose from the pressure plate.
When reinstalling, you pry the bearing back into place and you will hear a click when it engages properly. |
Anyone know if this applies to a '95 Rodeo, V-6 5sp manual, as well? |
Yes, it does.
Thank you much for the reply! Any idea what the pry bar looks like? Could I use a long screw driver? Thanks again for any info you can provide. |
Here's a picture.
Thanks cat. I found another way. Remove the pivot pin from the clutch fork then remove the trans, reassemble the clutch fork inside the bellhousing then assemble the trans with the fork and t/o bearing installed in the bellhousing. Once the trans is bolted back to the engine push the t/o bearing into the pressure plate until it snaps into place. This way works perty good for me and dosnt damage the diaphram on the pressure plate.
I wanna 95 Sonoma witha 871 blown 454 for a daily driver. Just cant figure out how to keep my a/c. |
Right on!
You guys just saved my backside. Have a great weekend!!!!! -Doug |
Re: Re: 1994 passport manual transmission removal
Cool. |
Re: Re: Re: 1994 passport manual transmission removal
Well, all the help has been great!
But now I seem to not be able to get the release bearing to "snap" into the wedge collar. I'm prying with a very long screwdriver through the round inspection hole in the bottom of the bell housing. Any ideas/suggestions? |
Your ideas urgently needed.
I have the same problem as uncledoug...trying to get the bearing to seat back in place. I have pried quite a bit and am afraid I could bend the fork if I try using more leverage or hammering. Same lack of results trying to move the other end of the fork, through the slave cyl. inspection port. Just so I know how this works, when the bearing is "clicked home", is the fork then very hard to move, as it is now actuating the clutch? Thanks, Sean in Michigan
1994 Rodeo 3.2l 4x4 5-speed Manual |
