Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
Old 05-29-2005, 11:06 PM
rice(er)'s Avatar
rice(er) rice(er) is offline
rotary vs. cylinders
which is better? disadvantages and advantages? whats the difference besides that the rotarty spins and cylinders go up and down or back and forth? your experiences with them? which do you prefer? anything else?
Old 05-29-2005, 11:36 PM
Muscletang's Avatar
Muscletang Muscletang is offline
AF Premium User
Rotary
PRO: spins to high RPMs, engine can handle high RPMs and gets to them quickly, makes lots of power for a rather small engine
CON: it has almost NO torque, nobody knows much about them so they're hard to service, known to break down after 50,000 miles
I'll let you make the choice.
For a long time it gave me nightmares... witnessing an injustice like that... it's a constant reminder of just how unfair this world can be... I can still hear them taunting him.......
silly rabbit, tricks are for kids...
I mean, WHY COULDN'T THEY JUST GIVE HIM SOME CEREAL?
Originally Posted by Lars Ulrich
What?! Record sales are slumping? Must be from all those pirates. Can't be because we started sucking 10 years ago.
Old 05-30-2005, 05:45 AM
christophv's Avatar
christophv christophv is offline
rotary engine have a bad mpg efficiency, and as being said, they aren't very reliable.
a big pro:
their layout allows very smooth revolutions and no "loss of power", as a cylinder engine loses much power due to lateral momentum forces (not sure of my language here)
for the torque thing -
a rotary engine doesn't need torque, because ist just a totally different engine layout.
cylinder engines gain their hp performance from torque, rotary engines from their quick response and high RPM.
they just use gears with very long ratios, where torque isn't necessary.
but I think, when rotaries want to compete with cylinders, they need to get rid of their reliability issue (which is possible with new materials such as high-tech ceramics) and rev even higher until like 12-14k RPM so they have a real advance.
still searching for a decent dorifto device
"If Nissan Motorsports is NISMO, is Honda Motorsports then HOMO?"
Old 05-30-2005, 09:59 AM
mason_RsX's Avatar
mason_RsX mason_RsX is offline
Send a message via MSN to mason_RsX
Another huge benefit to the rotary engine is that it weighs alot less than a regular cylinder engine. This makes it alot easier to achieve 50-50 weight distribution
2002 Acura RSX Type-S
Originally Posted by SiGNAL748
I have an outrageously large penis.
Old 05-30-2005, 07:56 PM
kman10587's Avatar
kman10587 kman10587 is offline
Send a message via AIM to kman10587
Re: rotary vs. cylinders
Well, this is a bit misleading. In order for it to make big power, you pretty much need to turbocharge and intercool a rotary engine. With the added weight of those parts, the complete package will probably weigh about the same as a piston engine that is comparable in power. Look at the 13B-REW vs. LT1: they both make about 280 horsepower, and they both weigh about the same. The difference is that the 13B uses high revs and tight gearing to keep in its powerband, while the LT1 has a wider powerband due to its large torque output, and wide gearing to maximize its top-end acceleration. Even smaller piston engines, like the EJ20 and 4G63, make considerably more torque than the 13B or Renesis. They are both good designs when it comes to power-to-weight, so it really comes down to what kind of driving experience you want: high revs and good weight balancing, or a wide range of power and proven reliability.
My '05 Impreza 2.5 RS.
Old 05-31-2005, 03:40 PM
NISSANSPDR's Avatar
NISSANSPDR NISSANSPDR is offline
Send a message via AIM to NISSANSPDR
I'd rather go w/pistons...personally
Yours truly,
Gabriel
Old 06-01-2005, 05:12 PM
rice(er)'s Avatar
coo, thanks
Old 06-01-2005, 06:20 PM
Pavlo's Avatar
Pavlo Pavlo is offline
Could always do a search...http://www.automotiveforums.com/vbul...rotary+pistons .
I would take a well built car, no matter what the engine is. Another rotary adventage is very small amount of rotating parts, therefore less things to break.
VR6> Anything
FWD sucks for understeer? Swaybars do magic.
