Old 05-29-2005, 05:55 PM
jacer63 jacer63 is offline
Lightbulb obd 0 - obd 1 conversion....
i recently converted to obd 1 from obd 0 in my 91 crx si.already have mini me swap done . now i wired the 4 wire o2 sensor, dizzy and msd cap for the p28 .now when i first started the car and didnt touch anything (gas pedal ,all accesories off) to learn the idle and what not. the car runs great after this ,then after being off for more than 15 min the computer has to learn the idle all over again and runs like poop till it idles for 10 mins! im i forgeting some kinda ground wires are somethin?it seems the computer wont save the info?acts like i take neg battery cable off everytime. any info are suggestions would help!!! thanks
please help@!!!!!
Old 05-29-2005, 10:38 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
u seem like a intelligent dude but ill meantion it neways, under the hood is a fusebox, make sure your ecu fuse is intact and not blown. goodluck man
Old 05-30-2005, 12:19 AM
well i did check the fuse under the hood and it is fine. it would not run if the fuse was blown would it? thanks for the suggestion.
Old 05-30-2005, 10:07 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: obd 0 - obd 1 conversion....
check the hazard fuse. i know that sounds dumb, but its the memory for the ECU and your radio. see if your hazard lights work...
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-31-2005, 05:12 PM
hey thanks for the suggestion. i did chack the hazard fuse and all fuses under dash also. i still cant figure out why the ecu wont save its memory!!i must of not hooked up a ground or something. any other suggestions would be appreciated... thanks
