Old 05-29-2005, 04:54 PM
codefrek5 codefrek5 is offline
Question 99 silverado w/4.3 question
I have had my 99 silverado in the shop 3 times in the last month due to the service engine light comming on. Each time it comes on it will start losing power and the engine will start bucking. the have told me it was the wires ( i replaced them) the next itme it was the injectors, this last time the fuel filter. The problem is the can't get it to repeat the problem at the service department. Also it only happens when it it raining or wet out. Has anyone had this problem or can help me?
Old 05-30-2005, 03:04 PM
airtight_python airtight_python is offline
Re: 99 silverado w/4.3 question
My 4.3L was doing that under heavy throttle. I never totally discovered what it was but since I have changed the fuel filter and spark plugs and it hasn't done it.
Old 05-30-2005, 03:11 PM
nineball481's Avatar
nineball481 nineball481 is offline
since it only happens when it rains, Do you think your distributor could be getting wet, or maybe the coil pack/s?
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 05-30-2005, 03:24 PM
That would be a possibility. I had my truck cutting out on the highway when it rained once.. then it wouldn't start. Turned out to be water in the distributor. It's a good idea to replace the cap ($30) and rotor ($13).
Old 05-30-2005, 06:42 PM
Thanks all, I had the dealer check the cap & rotor they told me it was fine, do you think I should still replace them? Also they told me there was a set of aftermarket wires on it, could this be part of the problem?
Old 05-31-2005, 09:45 PM
internic internic is offline
ive heard the mass airflow sensor sometimes doesnt like rainy days. i wouldnt think aftermarket wires would affect it. maybe you could rent a code scanner and plug it and go drive around when it rains
Old 05-31-2005, 09:52 PM
rabt's Avatar
rabt rabt is offline
the 99-02 4.3 had this problem with rain and the cap and rotor .... replace them ..... there is a tsb on it somewhere
2001 Silverado Extended Cab LS V-8
Rare Sunset Orange Metallic
